A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
Preguntas 687 Ver todo
Ps4 randomly shuts down
I am having a problem with my Playstation randomly shuts itself down. There is no warning nor red light. It shuts down like it was cut out of power. Powering it on immediately after the shutdown gives around 10 sec of blue light then it shuts down. What I do is unplug the device from electricity for a minute then plug it back in and it works. The shut down happens randomly. Sometimes it works for an hour or it stays up for 4-5. Though it never stays more than 6 hours.
( it's a shared console. My brothers play as well)
I have the console horizontal and nothing near it ( so it can get as much air as it need ). Bought an external fan in case it was a heating problem, but the problem is still there ( the fan is connected to the TV ). Since I live in an area where warranty doesn't count, I decided to open up the console and I did clean it. I have also rebuilt the database.
The device is connected to a UPS. Tried to connect it directly without the UPS, but it still shuts off.
Any hint on what else I should be trying? I can't send it to repair ( can't trust "repair" shops here. It's Iraq...) I would rather sell it and get the slim version, but I would love to try to fix the device.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
Finally, I know what this is all about
por
If you're still having this problem, go to [settings] then [initialization] then [initinalize system] and click [full initialization]. If that does not work, go into "Safe Mode" and click [rebuild data base]. Also make sure your system is up to date with its updates. Hopefully this helps !
por
Mine PlayStation 4 has same problem but worse now doesn’t let me go on it and asks my to do something with the new PlayStation 4 system file
por
Agregar un comentario
6 Respuestas
Is there any signs of overheating? It seems the system may be getting too hot and shutting down to protect itself. Is the console hot (I know its redundant for you being in iraq)
Fue útil esta respuesta?
Calificación 1
Comentarios:
It gets hot that's why I bought an external fan. Shouldn't it change the light to red before shutting down? Mine doesn't.
por
In most cases yes, it will warn you with a red light before shutting down, Is your ps4 in a non dusty area? If not the interneal fan may need cleaning
por
I did do that. I opened up the console and cleaned the fan.
por
Now that we eliminated one issue, lets talk power. Do you lug it directly into a wall? I use a surge protector. If you do have yo tried other plugs?
por
Yes, I did that and I even moved to another rom just to check.
por
Mostrar 2 comentarios más
Try just to turn it on and let it on home menu. Disable auto turn off and let it before you go to sleep, remove any connected controllers, camera or disc from console. Try to have all usb ports with nothing on them, usb sticks hub, and Ethernet cable disconnected, I would also recommend to remove it from any wifi network if it is connected.
If next morning is not off then it must be something wrong with power supply which cause it to turn off when is in load.
Hope this will be the beginning of your solution!
Calificación 0
Set Time Until PS4 Turns Off. To set the amount of time your PS4™ system can remain idle before it either enters rest mode or turns off, select (Settings) > [Power Saving Settings] > [Set Time Until PS4 Turns Off]. You can set the time separately for [Media Playback] and [General (Applications)].
Calificación 0
Maybe its still an overheating problem , try changing the thermal paste.
Calificación 0
it sounds like your ps4 has a contamination issue..ie...dust....it can destroy electronics...remove the covers and use can of compressed air such as keyboard cleaner to get dust from device.
Calificación 0
If with or without UPS the problem persists you can also try change power cord and check it with another power outlet if possible. If nothing of the above fix it then power supply of PlayStation 4 is probably faulty. If you are about to open the power supply BE EXTRA CAREFUL and you will need a multimeter ! I would recommend to buy a refurbished one, be careful with the model of the power supply you already have and find the same or a compatible one, there is model name on the power supply itself.
Calificación 0
Añadir tu respuesta
Alameen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 104
Últimos 7 Días: 578
Últimos 30 Días: 2,921
Todo El Tiempo: 23,420
