Is it possible to replace the glass only of an S8 Plus?
I am simply wondering if you can replace just the glass of a Galaxy S8 Plus, or if that is impossible. If it can be done, how does one go about it? I've had the phone for a month and the glass shattered.
Es esta una buena pregunta?
5 comentarios
It is too hard to do it
- de Kaye
If I change the glass of my phone galaxy s8+
How long it will work?
- de Fardaus Nourzai
Ignor all these people saying something isnt doable. If everyone had this attitude, we would still be in the stoneage. Its very possible with dry ice and caution.
- de John Grimes
@pccheese is right about the glass being fused. The glass is only the outermost layer (the part that you touch), which is fused to the LCD (liquid crystal display: part that displays the image), which is then fused to the digitizer (the part that responds to your touch). I wouldn’t recommend trying to fix it yourself unless you have all the proper tools and/or equipment. Take it from someone who knows and has actually attempted to do so.
I have a Galaxy s8 plus. Initially, the only issue I had with it was just a cracked front glass. I had already seen tons of YouTube repair tutorials and googled DIY instructions. So, I figured why not try to fix it myself. It’s harder than it looks if you’re not well equipped with the right tools.
If you do decide to fix it yourself, chances are you will probably end up damaging the LCD along with the digitizer in the process of trying to remove the glass. So consider buying a glass that comes with the lcd & digitizer pre-assembled.
- de Mr Uber619
To Mr Uber619, don't try and be a know it all, it doesn't suit you.
Sam's don't use LCD's in the S8 it's AMOLED (active-matrix organic light-emitting diode)
There's a few companies which do offer a glass only replacement service and there's videos of it being done on YouTube so it is most definitely possible!!
- de t1neo
