Saltar al contenido principal
Como puedo ser una cámara de vigilancia con esas misma cámaras y poder ver en vivo en el momento de la grabación por mesilde el waffi
Preguntas 991 Ver todo
Phone freezes while restarting
I have an Alcatel one touch and it froze the other day and when I took the battery out to restart it won't come back on at all. It will freeze on either the android symbol or the tracphone wireless screen. It won't load any further than than. Straight talk couldn't help me when I called so maybe someone on here can help please. I have factory reset multiple times and it's still not working. Help please!
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
try wiping the cache partition this will give you a clear cache for a clean boot. Factory resets don't clear the cache and its apparent the boot loader that's in the cache is corrupt . To do this shut the phone off completely then hold the power button and the volume up at the same time once it powers on release the buttons and it should take you to the android system recovery .Navigate to wipe cache partition by using the volume button and when you reach the wipe cache partition press the power button to select then once it completes select reboot system now and then it should work . If this brings no joy then you will need to try updating from the same menu and if it still doesn't work then you will need to load a new ROM. Hope this helps
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Desirea Rankin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 1,595
