Saltar al contenido principal
Apple Watch Series 2, anunciado el 7 de septiembre de 2016 y lanzado el 16 de septiembre de 2016.
Preguntas 132 Ver todo
Help! Debris stuck in Digital Crown!
Hello iFixit! I need a bit of help here because I cleaned my Apple Watch Sport 2 With a alcohol prep pad, and some of the cloth is now stuck inside the digital crown, making it hard to turn on occasion. My nearest Apple Store is 2 hours away and I have all the tools to DIY it. What should I do?
Es esta una buena pregunta?
Puntuación 2
1 comentario
I would also like if it could be done without opening it as I like my waterproofing seals!
- de
Agregar un comentario
2 Respuestas
Solución Elegida
@reedcrosby,Reed, You may have to get yourself a cheap dollar store magnifier/glasses to aid in seeing if fibers are accessible to dislodge with a small pin/compressed air(should work). If not then you may have to partially disassemble watch to get at debri. Link below shows how to disassemble, if need be. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Apple Watch Series 2 Teardown
Fue útil esta respuesta?
Puntuación 3
3 comentarios:
Thank you! I never thought of that...
- de
@reedcrosby, Reed, Welcome, thanks for replying back and good luck with your Apple watch.
- de
Thanks for the luck, I might need it!
- de
Try getting some tweezers and just slowly getting rid of all the fibers, they should eventually come out.
Puntuación 1
1 comentario:
I would, but the issue is I cannot see them but I can feel the resistance from them.
- de
Añadir tu respuesta
Reed Crosby estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 33
Todo El Tiempo: 2,907
