counter top speaker & dock station for your iPhone
Preguntas 2 Ver todo
Bass speaker vibrating loudly, distortion
I need it replaced, are you able to help
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Check Your Speakers: Have you had your speakers for a number of years? Even the best speakers can only last so long. If you have been using them for quite a while and have been especially heavy with the bass, the speakers may be blown. When that happens, there will be considerable distortion.
Run some tests, but your distortion problem may just be a matter of having to replace older equipment that no longer functions properly.
Amplifier Clipping: If you love hard rock and your neighbours do not mind, it is very tempting to blast your heavy metal tunes as loudly as you can. However, it is a bad idea to overdrive your amplifier beyond its maximum capacity. This results in what is known as clipping.
While some electric guitar players do this intentionally to produce a certain sound, the average consumer will not find this desirable because it affects the quality of the music they are listening to. Consult your speaker specifications and try to remain within the output range that is listed. Besides, listening to too much loud music is going to ruin your hearing and you will not be able to enjoy the music anyway.
Check Your Audio Cables: Complicated stereo systems often rely on quite a few audio cords. This can result in a snake-like mess of intersecting cables that can become easily tangled. If this happens, it can affect their ability to function correctly and that can be a cause of distortion.
Check your cables and untangle any that are not hanging freely. Also be sure to check that they are correctly plugged in is that can be an issue as well.
Driver Failure: Your speakers contain a driver that is a transducer which converts electrical energy into sound waves. As you can imagine from that description, it is an important part of your music delivery system. A driver can be subject to failure and this will have a significant impact on the sound quality that your speakers are delivering.
Determine which driver is malfunctioning by switching the left and right inputs. Once you have done this, try and find an original replacement driver or make necessary repairs. This can involve replacing the cone assembly and related parts, or it may be necessary to invest in a new moving assembly.
Go Easy on the Bass: Depending on the kind of music you love, it is tempting to crank up the bass in order to get a really strong, hard rocking sound. If you are listening to music in the car, is also tempting to boost the bass as a way of drowning out background traffic noise.
Unfortunately, bass can take a toll on your speakers, resulting in a lower quality and sometimes distorted sound. In order to prolong the life of your speakers, cut back a bit on the bass and try adjusting your other amplifier settings to give you a richer sound that will not be so hard on your system.
Add a Compressor: Another source of audio distortion can be peaking. If your equipment is peaking, it means that you are pushing it too hard and beyond its specifications, which can lead to compromised audio. Adding a compressor to your system allows for further amplification than you would normally get without the problems that this would cause.
Check Your Microphone: If you are using a microphone, where you place it can make a difference in the quality of the audio your system is outputting. Is the microphone picking up background noise that is not meant to be part of your presentation? This can cause distortion in your audio. Try moving the microphone to a different position.
Clean Your Volume Knob: If the distortion is occurring when you adjust the volume on your amplifier, the problem might be a case of dust or other contaminants.
Buy a can of compressed air and blast the air around the inner rim of the volume knob. If you can, open your amplifier and remove as much of the dust in the area around the knob as possible. Dust is bad for electronic equipment anyway and you should try to do this every few weeks to ensure that your equipment will last as long as possible.
Visit the Professionals: Like all hobbies that require a certain degree of technical sophistication, there are any number of experts in this field who can advise you.
If you are not able to detect the problem using the methods we have suggested, make an appointment with one of the stereo specialty shops in your area. Their technicians will be able to determine exactly what is causing your problem and offer suggestions on how to correct it with some technical adjustments or replacement equipment.
Listening to music can be one of the great joys in life, but that pleasure can be significantly compromised if your speakers are not delivering quality sound. Distorted music is unpleasant to listen to and if you are trying to get rid of speaker distortion, there are several steps you can take to correct it. If you are not a sound expert, this can be a bit daunting, so try consulting a friend who knows his way around a stereo or visit one of the stereo shops in your area for advice and directions on how to have your music sounding as pleasant as you wish it to
Fue útil esta respuesta?
Calificación 2
Comentarios:
@albert963 - This is very generic and doesn't really answer the question.
por
OK simple, from where you get this return back.
But
Go for these points may be these are the reasons for speaker base vibrating loudly. may be you will be help fulled. Please checked
  • External resonance - vibration of an object near the TV
  • Internal resonance - vibration of something inside the TV
  • The speakers themselves, or
  • A faulty main (signal) board
Calificación 2
Añadir tu respuesta
Peter Smith estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 20
Últimos 7 Días: 136
Últimos 30 Días: 638
Todo El Tiempo: 3,893
