The Officejet is HP's line of office inkjet printers.
Preguntas 221 Ver todo
Why is it saying there is a problem with the printerhead?
I am getting error code that says there is a problem with the printer head
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Respuesta
Solución Elegida
Susan Costello, You did not state your model#, Start your trouble shooting of print head error using the links below. In some forums they say if you contact HP they may replace the printer as this is a known issue for some models to have a bad print head, may be worth looking into. If under warranty and no go, return for replacement/repair/refund. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://support.hp.com/us-en/product/HP-...
https://fixingblog.com/fix-print-head-pr...
Fue útil esta respuesta?
Calificación 1
Añadir tu respuesta
Susan Costello estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 102
