Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How can replace battery? (pinout)
Hi friends.
I want to change my ultrabook battery with an after-market one. I already found few batteries with same voltage value but I have a problem. Normally most of the notebook batteries have 9 pinouts (3 ground , 3 V+ , 1 SMC+ , 1 SMC- and center pin) but somehow this notebook has 11 pinouts , you can see in below picture.
What I was wondering if is there a way to connect a battery with 9 pinouts into my ultrabook`s motherboard which has 11 pins ? Maybe there is a converter that I am not aware of ? Or I can simply align the pins by soldering some pin cables ?
https://i1.wp.com/www.techniumc.com/wp-c...
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Tf there are more grounds/ v+ ==> you can just make an adapter, but when I was disassembling my 12.5 I saw, that there were data pins, so your power controller possibly will not recognize your battery.....
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Seçkin Güvenç estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 3,577
