Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2693 Ver todo
iPhone 6s battery draining fast even after replacement battery twice!
Hi ,
Guys I replace my battery because it was draining fast
but I notice it still draining fast , better than original battery but still draining fast
so I was thinking maybe the new battery is defective
So I replace battery again
and still it's draining fast !!!
What is the problem ?
Is there something else will make my battery draining fast ??
Es esta una buena pregunta?
Puntuación 5
Agregar un comentario
3 Respuestas
Solución Elegida
Hi,
Been using cheap cables I guess?
You have damaged the tristar chip, when this is damaged, it can drain the battery extremely quickly.
You would need to take it to someone who does microsoldering, and can replace the tristar chip. :-)
Fue útil esta respuesta?
Puntuación 4
10 comentarios:
I never ever used a cheap cable , I used the original cable came with iPhone
- de
Any liquid damage? Any recent drops? Charging in car? So you've never ever used a friends cable when you haven't got yours?
- de
I always have a cable with me , I use I power bank from Anker
the same power bank I used before iPhone 6s , I never have problem with battery on my old iPhone
and no there isn't any liquid damage
BTW my iPhone 6s had a problem with battery that Apple talk about
https://www.apple.com/support/iphone6s-u...
But in my country there isn't apple store
- de
Is IC or U2 or Tristar is different name but same chip ?
- de
Yes basil same chip.
- de
Mostrar 5 comentarios más
Hi, I still have the same issue even after new battery and IC replacement. Is there anything else that can have the problem?
Puntuación 0
I buy a lot of iPhone aftermarket batteries. I estimate that 25% are “poor” when new. 75% are “very good to excellent”.
I was buying great batteries from a specific vendor, and suddenly they changed suppliers I ended up with a bunch of duds that couldn’t hold a decent charge. So beware that someone else’s experience with a vendor may not be the same as your experience.
Similarly, not all battery adhesive strips are the same. Some are good, but some of these adhesives are made so poorly that you’ll never be able to release them properly. I got a batch of bad adhesive, and battery re-replacement became a huge time sink as I spent far to much time trying to release the battery, followed by more time trying to remove the sticky remnants of the lousy aftermarket adhesive.
Puntuación 0
Añadir tu respuesta
Basil estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 4,854
