MacBook Pro models with 13" displays
Preguntas 5602 Ver todo
I'm trying to retrieve my iPhoto's that were put on my book
Hello. I recently put all of my iPhotos and other items on my macbook pro onto my book. I am now trying to put them on a new macbook pro however when I open up the app on the computer I cannot find any of my photos from my iPhoto app
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
What do you mean onto your "book"? Do you mean another MacBook?
por
My Book is the name of the storage unit -- I put everything on my one macbook onto "My Book" and am trying to open up my files on a new macbook and cannot find my iPhotos
por
It says this when I try to open it --- None of these files can be imported into your Photos library.
por
@pccheese, I think this is the type of storage:
http://support.wdc.com/cat_products.aspx...
por
Is there any reason why you are trying to open in iPhoto and not the new Photos app?
por
Agregar un comentario
2 Respuestas
Respuesta Más Útil
You don't want to use iPhotos to import. Instead, you should use the new Photos app.
Press and hold the alt/option key when opening the Photos app, and it should let you choose a location to import from. Select the old iPhotos library from the drive. Photos will then create an updated copy of the library that will also be shared with iPhoto to save space.
Fue útil esta respuesta?
Calificación 2
Comentarios:
Hello. Just wondering which photo's app you are referring to??
Thanks!
por
It's the new one from Apple called Photos. Should come preinstalled on all of their devices now.
por
Yes that's what I've been trying to do but every time I press it it says "nothing to import. None of these files can be imported to your photos library"
por
I would recommend trying to use PowerPhotos https://www.fatcatsoftware.com/powerphot...
por
When I open the folder with my pictures from "my book" it doesn't allow me to open with power photos -- oh man
por
Mostrar 2 comentarios más
I would download and install a utility like
OmniDiskSweeper
that will sweep through the hard drive and show you the results in a
window to see where larger folders and files are.
The iPhoto library should be large.
Calificación 0
Comentarios:
unfortunately that did not work either ....
por
Try Yodot to recover the pictures. You can download it here: https://f106c2fdc37239d65fa2-3e4b8066b30...
por
Añadir tu respuesta
blueeyedb712 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 4
Últimos 30 Días: 17
Todo El Tiempo: 270
