Saltar al contenido principal
I need help! I need a tear down guide for Everest 700
So my warranty on my headphones expired and the power button broke on my headphones. I try to press the button but it's already pressed down and it wouldn't click. I need immediate help to tear down these headphones!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
2 comentarios
Did you find a way to tear it down, got the same problem
- de
Does anyone know how to replace the battery?
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
So if you need to take apart the headphones start by taking off the earcup the move on to the four screws that hold the speaker on. Next there will be 2 screws and rubber tabs. Take out the screws then pull all tabs up don't rip them just straighten them out. Now look under the piece you were just working on. This should be the base were the rubber tabs enter the piece above. Gently pull where each tab would be untill all are removed. Now you should be able to get to the board of the headphones
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Garrett estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 1,419
