Saltar al contenido principal
Android smartphone with a 5.15" 1080p display and a Qualcomm Snapdragon 820 processor. First released in 2016.
Preguntas 48 Ver todo
Phone not turning on, no leds blinking at all!
My mi 5 was rooted and was installed with aosp rom. I downloaded a battery calibration app, where it was instructed to start calibration and then when the phone switches off it should be charged to a 100 percent. I had unplugged my phone at 97 percent, but I couldn't switch it back on. There were no leds or anything. I also tried to charge it but now it wouldn't show anything . How can I fix it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 6
7 comentarios
me too i have the same problème.
- de
Hi,
I had a similar problem, my phone turned of and I wasn't able to turn it on, or charging, there wasn't any leds.
I repaired it by opening my phone (very easy) and unpluged an repluged the battery connector.
I think there is a generic default with xiaomi mi5 battery...
Hope it helps !
- de
Wow great answer Geoffrey had the same exact problems and followed your advice found a tutorial on how to disassemble a xiomi 5 on you tube opened it unplugged replugger the battery and now it works !!!!!
Thanks again Geoffrey I how you a beer !
- de
I have the same problem. Any solution?
- de
Dizefurkan,
You can open your phone and unplug then replug the battery connector (you will easily find a tutorial for it), I made this a few times, but I think, it's just a temporarly solution, mine juste completely die after 8th times...
- de
Mostrar 2 comentarios más
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Hope it helps !
by Geoffrey Borelli
Fue útil esta respuesta?
Puntuación 1
Hi
Try yo flash marshmallow roms via fastboot or mi flash
Puntuación 0
1 comentario:
will it work?
- de
Hello,
My Xiaomi Mi5 had a battery drainage. It was heated so much that I was not able to hold it. After some few minutes, it turned off and I was not able to switch it on. I tried to charge it; no led glows. Its just like a dead mobile phone.
Puntuación 0
2 comentarios:
i am facing such type of problem, started with unresponsive touch screen . now it totally dead
- de
Did you solve the problem?
- de
Añadir tu respuesta
Fragout Gaming estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 19
Ultimos 30 días: 57
Todo El Tiempo: 6,485
