Saltar al contenido principal
El chasis W123 cubre 240D's, 300D's, 300TD's, 280E's y varios otros modelos de coupé, sedanes y vagones Mercedes de los modelos 1977 a 1985.
Preguntas 116 Ver todo
Low fuel warning stays on
Fuel low warning lit up with 3/4 full tank. I filled the tank, the light stayed on. I removed the sender and disassembled it and cleaned it. I got a little bit of the black crap out of it but nothing that could bridge the contacts at the bottom. I put it back together and the light stay's on. Bummer. The fuel gage seems to be accurate, the 3 wires are good.
Anyone know where I should look next?
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
@old_pat ,Pat, link below had similar issue and stated they had to add additional ground to back side of gage cluster. See link below for more info and pic's. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.benzworld.org/forums/r-c107-s...
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Pat Sweeney estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 1,685
