Saltar al contenido principal
My laptop hinge is broken/stuck?
My asus laptop hinges sudden just broke, they are covered by these plastic pieces, but those broke off because the metal is stuck in one position and now my computer screen is only attached to my keyboard by the wires and cant stand on it's own.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
This happened to a laptop of mine several years ago, without warning the hinges seized and the metal part of the frame that was attached to the hinge snapped and cracked the front and back plastic, and it was left in the same condition as yours. HP pavilion, never again.
You should check your warranty status before paying to have it repaired or attempting to repair yourself.
Here is a video of a screen disassembly the hinges look relatively simple to replace, however if the back plastic plate is damaged you'll need to replace that too.
Let me know if this helps.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Hannah Dodson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 4,593
