The latest phone in the HTC One line, simply called the HTC 10, released in 2016.
Preguntas 25 Ver todo
The htc 10 doesn't have a way to open the phone
the htc 10 doesn't have a way to open the phone to remove the battery will the bag of rice still work?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
2 Respuestas
Solución Elegida
Hi,
I'm assuming since you mentioned rice that your phone has gotten wet, is this correct?
As you know water and electronics and electricity are not a good mix.
The minerals in the water, cause corrosion and the water also provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion process starts immediately and will not stop until it has been thoroughly cleaned away.
Rice is good to eat but does nothing to fix the problems caused by corrosion.
Don't Put Your Device in Rice. Here's Why
First do not turn on your phone and then you need to with the phone turned off, remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to completely dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available from most pharmacies) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% or less, can also contain scents and is not as effective. If you do check the label to verify the amount and ingredients
Here is a link that in general describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Here is a link to the ifixit repair guide for your phone which may be of some help.
If this process seems too daunting, take your phone to a reputable, professional mobile phone repair service experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Fue útil esta respuesta?
Calificación 3
@jayeff I think that OP was referring to heating a bag of rice to use an an improvised iOpener.
I know I'm necro-ing this question, but since I stumbled on it because iFixit SEO is so good I thought that a link to a disassembly might be helpful for anyone else that might run across it as well ::
- https://www.fixez.com/guides/htc/htc-10-...
Calificación 0
Añadir tu respuesta
charlise3 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 5
Últimos 7 Días: 68
Últimos 30 Días: 308
Todo El Tiempo: 2,886
