Saltar al contenido principal
Manufactured from 2004 to 2009, the Vino 125 has a 125cc engine.
Preguntas 22 Ver todo
Oil Filter on a 2008 Yamaha Vino 125
Hello, I am having trouble locating the oil filter on this scooter. Here is the oil filter I purchased:
https://www.amazon.com/gp/product/B000E2...
Can someone point me in the right direction of where to find this?
Thanks,
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
john.intemann, Pic. below may help to locate filter on your 125, and a link to manual(may not be your exact year, but could help). Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.yamaha-motor.com/assets/servi...
Fue útil esta respuesta?
Puntuación 2
The oil filter assembly is located underneath the cylinder head next to the center stand. There are three bolts on the bottom and one on top that need to be removed. You also need to buy the oil filter gasket and the two copper washers for the top bolt. Be careful not to over tighten the top union bolt as it is a hollow aluminum bolt that will snap easily of over tightened.
I’m not sure if this step is necessary but I removed the exhaust to easily access the area for the oil filter.
Lastly, make sure you put the oil filer in the correct direction, the slotted end is pointed towards the front of the bike. This was confusing for me as the manual shows the smooth side facing forward
Puntuación 1
Añadir tu respuesta
john.intemann estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 39
Todo El Tiempo: 5,002
