Saltar al contenido principal
Unibody de aluminio de 13", procesador Core 2 Duo de 2.0 o 2.4 GHz.
Preguntas 574 Ver todo
Right LCD Screen Assembly hinge lock broken after drop
Well, i just dropped my MacBook Pro 13" Mid-2012 and the right hinge broke, but not the movable part but the hinge on the screen assembly
Is there any way this can be fixed?
Image included.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
The part you highlighted is attached to a large frame thing inside the display assembly. You can access and replace this frame, but you will have to remove the glass and the LCD panel first, which is quite a time consuming repair (MacBook Pro 13" Unibody Mid 2010 LCD Replacement). Then, you can take out the screws that hold the frame in place, heat the adhesive and the frame will separate from the back cover. I don't know of any sources that sell just the frame, so you will probably have to salvage it from another LCD assembly.
It's most likely the best for you to just buy a whole display assembly and replace the broken one with it. (Reemplazo de Pantalla MacBook Pro 13" Unibody Mediados de 2012)
Imagen de MacBook Pro 13" Unibody Mid 2010 LCD
Guía
Dificultad:
Muy difícil
2 - 3 hours
Imagen de MacBook Pro 13" Unibody Mid 2012 Pantalla
Guía
Dificultad:
Moderado
30 minutes - 1 hour
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Robert G estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 142
