How can I remove a CD stuck in the CD drive
A cd was already in the cd drive and another cd was put in the same cd drive how can i remove them
Es esta una buena pregunta?
Step 1 (if you are truly lucky): Boot up while holding down the trackpad button to eject the CDs.
Step 2: Access the drive itself, remove the cover, and remove the CDs.
Good luck!
Fue útil esta respuesta?
I have had this problem with a CD with a stick-on label. Answer:stick your finger nail into the CD slot and pry the case up gently at the same time you hit the "eject" button or command- E. Works for me!
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 4,012
