Saltar al contenido principal
Anunciado el 9 de septiembre de 2014, este dispositivo es la primera incursión de Apple en dispositivos portátiles inteligentes. Los manuales de reparación de iFixit son aplicables a Apple Watch (acero) y Apple Watch Sport (aluminio).
Preguntas 210 Ver todo
Batteries interchangeable between series?
Are Apple watch batteries interchangeable between all the different series? Say I need to replace a 38mm apple watch battery (original), can I use a 38mm battery for series 1 in the original?
Es esta una buena pregunta?
Puntuación 1
2 comentarios
Can I use the Apple Watch battery from a series 1 for a series 2
- de
Hi,
Is the apple watch series 1 and series 2 batteries interchangeable ?
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Sorry no, The original Apple watch uses a different connector system for most everything and that includes the battery. See for your self here:
Original Battery
Series 1 & 2 Battery
Fue útil esta respuesta?
Puntuación 4
**Editing to say that I am 100% sure you can swap batteries between the First Gen and Series 1 Apple watches because I’ve successfully done it countless times.**
I'm pretty confident that you can use a battery from a Series 1 Watch in an Original Apple Watch. The internals between the Original and the newer Series 1 are almost identical. (The processor was about the only change.) In fact, if you order a replacement battery from ifixit.com, the batteries are listed as being compatible with either Watch. Also, the details about the used OEM batteries listing even says that they are taken from either an Original or a Series 1 Watch.
Apple Watch (38 mm, Original & Series 1) Battery
[producto vinculado inexistente o deshabilitado: IF308-010]
Series 2 is different though and cannot be used in the earlier models.
Imagen de Apple Watch (38 mm, Original & Series 1) Battery
Producto
$16.99
Puntuación 2
Añadir tu respuesta
Sheila Smith estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 39
Todo El Tiempo: 2,271
