Saltar al contenido principal
El MacBook Pro 15" reemplazó al Aluminio 15" y cuenta con soporte Intel y una cámara iSight integrada.
Preguntas 1322 Ver todo
MacBook will only power on if the battery is unplugged
Hi so I have a problem. I found my old Macbook Pro 15 in non-unibody from 2008 I believe. I am really inclined to get it to turn on. So far the only method that has worked to get it to turn on is if I remove the battery, hold down power button for 10 seconds, plug the charger back in and continue to hold power button for 10 more seconds then release it. Only then, do i hear it turn on and the fans spinning. However, I get no display on the screen whatsoever. I don't know what to do any advice will be helpful. I want to open it up and maybe check the display cable but I don't know if that will help.
Also,
my battery isn't in the best condition, it looks like it is peeling apart or something. I was thinking maybe I can just tape it up but I don't know. any help/advice will be appreciated
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Yeah, get a new battery. That one is 'expanded', meaning you are lucky it hasn't exploded and caused fire. Your battery was probably part of the Apple recall a while back but you missed the boat.
Amazon has some great 3rd party batteries. Just read the reviews on the best one to get.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Mel Chillington estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 75
