My phone cant Turn off.
My phone cant turn off as it is stuck on samsung logo.And whenever I hard reboot it gets stuck again on it. How do i get into recovery mode without turning off.?
Es esta una buena pregunta?
Hard shutoff is Power + Volume down + Home for 8-10 seconds.
After that quickly hold Power + Volume Up + Home and release power button when you see the Samsung logo but keep holding the rest. It should boot into recovery mode shortly after 15 seconds.
You can try doing a wipe data / factory reset if you absolutely have no user data you want to keep on the phone but it most likely won't fix the stuck at boot issue.
You will most likely need to reflash the Samsung Firmware on the phone using ODIN with downloaded firmware from Sammobile or Updato or use the software called Samsung Smart Switch with emergency firmware recovery option selected.
More info here:
Fue útil esta respuesta?
Thank you so much for this advice/information! This never happened to any of my phones before, didn't know what to do!
my samsung galaxy s6 is a verizon one, y tried to updated via verizon upgrade assitant and it fails, right now the phones do not enter in download mode only maintainace mode, i've tried everything and the phone wont boot up
This solved the problem perfectly.
U people are great
Ultimas 24 horas: 3
Ultimos 7 días: 18
Ultimos 30 días: 80
Todo El Tiempo: 15,000
