Saltar al contenido principal
The 2009-2014 Ford F-150 was introduced for the 2009 model year as an update of the Ford full-size truck platform.
Preguntas 73 Ver todo
Rear brakes ceasing after break job?
After having the rotors and pads replaced on my 2011 F 150 FX 4 the rear brakes have ceased up after I have put it in reverse to back up. When I get out the brakes are super hot once I put it in drive and go a short distance. But it seems to let go after a bit.
Are the brakes not seated correctly for this to be occurring or was this an improper installation?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Mark , You may have adjusted them up way too high, ebrake cable could be sticking, adjusters not assembled correctly, etc.. Ensure pins and slide lubed and moving free and pads sitting in proper position. Maybe take apart again and check all your work, is it both sides on the rear and is it disc brakes. Video and guide below may help. Good luck.
https://www.youtube.com/watch?v=FIuv341T...
http://www.paulstravelpictures.com/Ford-...
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Thanks, this was a job I did not do. It was done at a Ford dealer. I went back, but the dealer claimed they could not replicate the problem. Yes they are disc brakes. I believe they are set up too high. I'm not a mechanic, but from the years of driving I have seen this in a similar situation in other brake jobs in the past . Thanks.
- de
Añadir tu respuesta
Mark Lafferty estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 77
