ps4 signal turns on with no signal on tv.
my ps4 turns on but shows no signal on the tv.please how do i fix that?
Es esta una buena pregunta?
I'm assuming that you've checked the HDMI cable and tried another cable. If that's the case then the most likely cause of this problem is a faulty HDMI port. This is something that most people don't have the skill to replace but you can check out my video to see if it's something you can do or not:
Fue útil esta respuesta?
I can't do all of that!!!
i cant do that im only 12 years old
Same bro like who do you think I am
I did all of that and put my PS4 back together.Then I pluggedd my hdmi in to test it out it still read no signal.What do I do?
Are you 100% sure you soldered the HDMI port on correctly...including the 19 small pins?
In this case it’s actually not my hdmi port cus I use the same port for my DStv decoder and it’s show on my tv but it says no signal any time I connect my ps 4
im sad i want be able to play fortnite. cuz my tv keeps saying no signal
I just had to switch out the HDMI cord for another one. ??
I’ve gotten a new hdmi cord and it still says no signal
Ultimas 24 horas: 5
Ultimos 7 días: 30
Ultimos 30 días: 188
Todo El Tiempo: 50,318
1 comentario
Hi sir how to fix a PS4 that appear 576p but no display after a second
- de Teraoi Teira
