The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
Preguntas 194 Ver todo
Galaxy Note 5 Wi-Fi and Bluetooth not working
My Samsung Galaxy Note 5 has problem with Wi-Fi and Bluetooth. Neither of them turns ON
I reset the device and didn’t work
The symptoms are: the Wi-Fi slide is OFF and grey, when sliding it to ON position it displays message “Wi-Fi Turning ON…” for few minutes and then it goes back to OFF; the same is with Bluetooth slide. I opened it to see if any wires were loose. All seems normal and all other functions of the device work fine.
Is it possible that the Wifi-Bluetooth modules are fried?
It looks like they are part of the mainboard. Can you suggest a diagnostic tools to determine if it’s in fact a hardware problem so I may start chasing the replacement part?
Thanks
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
I think the microchip of wifi/bluetooth should replace it
por
I accidentally dropped my Samsung Galaxy Note 5 and then the wifi and Bluetooth won't turn on anymore. What seems to be the problem? Can this be fixed?
por
Agregar un comentario
1 Respuesta
Solución Elegida
solution? . . . . . . . . .
Fue útil esta respuesta?
Calificación 0
Comentarios:
Does the phone have the latest update installed?
Also, did this just start happening or has it been doing this for a while?
por
Añadir tu respuesta
Omar Zn estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 19
Últimos 30 Días: 79
Todo El Tiempo: 917
