heating coil inbottom of tub burnt in half
the Black ring heating coil on the bottom of the dishwasher tub(circular heating element) actually burnt in one spot and it burnt in half. I replaced the heating element with a new one around 30 dollars but the dishwasher will not heat the water or dry dishes after replacing it. I feel something else caused the element to actually burn in two but im not dure of what it is. there is a high limit thermostat that can be replaced but I dont know if that will correct it. Also after replacing the heating element,do you have to reset the controls in any way? thanks Tom
Es esta una buena pregunta?
4 comentarios
thank you two folks for your reply. I will check out that thermostat and see if thats the problem.I thought it might have been that ,so I ordered one on line ,expect it here in a few days. thank you both for taking the time to reply to my question. When yhe thermostat comes and I replace it I will let you know if it was the problem, thanks, Tom
- de tommy gee
was that the problem? i'm having a similar issue with my heating element
- de Drew DiPaolo
You have to put it though the diagnostic process after changing the coil. I could not understand the same issue myself but I did it and it worked again after I gave up 3 years after replacing it...look up how to do it on YouTube it’s very easy
- de mark gresser
Hi I have a beko dfn2000x dishwasher wasn't heating up so changed the flow heating element and thermal sensor ,and still doesn't get hot I herd the dryer come on but still no heat Steve
- de Stephen Lawrence
