Replaced Screen, works, but goes into boot loop, fixed by taking apart
My wifes iPhone 6 has water in it killed the screen but the water slash liquid wasnt like conductive, it was a medical water thing for the ears.
Anyway ordered a new screen replaced it all and it worked fine. But the next day it turned off, i took it apart again and as soon as i got the screen off it turned on and worked perfectly. So issue is once i close it it stops working.
It happens when i put the top pins in and bend the screen into to close someting seems to be making it reset into a boot loop and dead.
Any ideas?
Update (03/15/2017)
UPDATE
Hi Team, so i managed to replace the camera & battery. First two days it worked perfectly everything is back to normal. No restarts no crashes.
Then today, it seemed I was bit rough in my movement with the phone and it crashed and restarted in my hand.
So, so far replaced:
- Main Camera
- Battery
- Screen
Basically if you hit it hard enough in your palm it restarts.... Any ideas what could be causing this?
Es esta una buena pregunta?
6 comentarios
Also if you shake it when it turns off it boots up again, but as soon as its in desktop it turns off again.
- de Patryk Lazarz
Unplug the front camera ribbon cable and see if it still boot loops.
- de Ben
Hey mate, which one is that ?
- de Patryk Lazarz
It is the first cable you disconnect.
- de Gigabit87898
Hey Ben, i did the camera thing first, no back facing camera but the %#*@ phone works fine after a full recovery.... wtf
- de Patryk Lazarz
Mostrar 1 comentario más
