Panasonic lcd tv Red light blinking problem
Panasonic lcd 24 inch tv red light blinking continiuosly but the tv won't turn so please any one help me ,how do i solve this problem
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
I tried (after trying several unsuccessful tips) switching off the TV for 1 minute (On the set). Then on the side of the set, holding the down program arrow button in and pushing and holding the on/off switch in until the remote light blinked green, keep holding it until the set came on. This was about 30 seconds. It worked. I notice that it now takes longer to get the set to start, but you can stop pressing the remote on once the indicator starts flashing green.
por
Great advice, I used this ti fix my mums television, thankyou
por
Agregar un comentario
1 Respuesta
Solución Elegida
Hi,
First try a power reset.
Turn off the TV and then turn off and disconnect the TV power cord from the power outlet. Then press and hold (or turn on ) the TV's power button (or switch) for 30 seconds and release. Reconnect the power cord to the power outlet and switch on the outlet. Turn on the TV and check if it starts OK.
If that doesn't work, switch off the TV and disconnect the power cord from the power outlet disconnect all the cables from the TV and remove the back cover from the TV.
Check the power board (the one where the power cord connections go to) for domed, leaking or blown capacitors and also for possibly any other burnt out or heat stressed component.
If unsure about a component take close up pictures of the component in question and post back here. Hopefully someone will be able to help you further.
Here is a link that shows how to do that.
Adding images to an existing question
Fue útil esta respuesta?
Calificación 2
Comentarios:
My panasonic led tv also blink red light I was check up power board its good . What can happen?
por
Añadir tu respuesta
mohamed rafeeq estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 80
Últimos 7 Días: 481
Últimos 30 Días: 2,242
Todo El Tiempo: 8,292
