Saltar al contenido principal
Manual de reparación completo para PSP Go, incluida la actualización de la batería y las instrucciones de reparación de la pantalla.
Preguntas 89 Ver todo
After reassembling my PSP Go the Start & Select buttons won't work
After i disassembled and rereassembled my PSP Go to fix my power switch; i used the PSP Go Teardown guide from this website, and now both the Start & Select buttons won't work anymore; and they were working before then.
so i tried taking my psp go apart and putting it back together again while going over the teardown guide thinking i over looked something, anyone have an idea of what that might be?
Es esta una buena pregunta?
Puntuación 3
1 comentario
Agregar un comentario
3 Respuestas
Solución Elegida
Look at the 2nd picture of step 9 in the PSP Go teardown. There is a cable that connects the buttons to the main board, it could be loose.
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
Here's a direct link to the page Aram is mentioning. PSP Go Teardown
- de
thanks man, that's exactly what the issue was, i didn't see that cable cause it was hidden by joystick's ribbon cable.
- de
I have the same issue, except my cable is in. Any ideas? I just had sound issue which was caused by bad fuse, which i replaced and now works but SELECT/START button doesn't
Puntuación 0
It comes out from the front. First detach from the motherboard and then take it out from the front. The Start/Select buttons are sticked on.
Puntuación 0
Añadir tu respuesta
joel c estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 6,162
