Saltar al contenido principal
Modelo de mediados de 2012, procesador A1278 / i5 a 2,5 GHz o i7 a 2,9 GHz.
Preguntas 1624 Ver todo
I have a Flashing Folder issue
Macbook Pro 13" i5 2.5 2012 Mid
When I start the macbook pro I get the flashing Question Mark. I've replaced the hard drive data cable and tried to boot from an external hard drive and still the same problem. Does anyone know how to fix this? Or is the logic board bad?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario
Have you reset the PRAM and SMC yet?
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
It's possible the replacement hard drive cable could be bad - I remember I ordered 5 of them once and 2 of them were dead on arrival.
Either that , or the hard drive itself requires replacement.
The flashing folder happens when the MacBook can't detect the operating system. If you have installed a new ribbon cable but the hard drive has failed, or a new hard drive but have not reinstalled the operating system, you'll see the flashing folder.
Easiest way to check would be to boot into either Recovery mode or off an install USB if you have one and load up Disk Utility.
If the hard drive appears and you can run First Aid on it and it passes, the drive should be fine.
If the hard drive doesn't appear when connected to the ribbon cable but does appear when connected externally, your ribbon cable is probably bad.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Renaldo Greenfield estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 92
