Eleventh generation of Ford's flagship pickup truck.
Preguntas 31 Ver todo
Why does seat belt not latch?
Seat belt won't latch
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
2 Respuestas
Solución Elegida
@bigredd , Todd Rediger, If you do not see any obvious obstruction inside the buckle that you can picked or blown out and the opposite (latch) end is straight/undamaged, it is recommended to replace the defective part for safety. The buckle lock tab/spring could be worn/damaged inside and are not meant to be serviceable. You could order a new replacement or check out the local auto recycler for the part as it would be low cost from them. Video link below may be of some help with belt replacement or if not wanting to do repair yourself, take into a good shop, have them take a look and estimate repair. Good luck.
https://www.youtube.com/watch?v=IgwfQZsE...
Fue útil esta respuesta?
Calificación 3
You need to give more details
1. Check if there is anything blocking the "receptor".
2. Check if any parts are broken
Calificación 0
Añadir tu respuesta
Todd Rediger estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 12
Últimos 7 Días: 118
Últimos 30 Días: 667
Todo El Tiempo: 4,938
