Wifi signal weak after battery change
After replacing battery in amazon fire phone, I was unable to connect to wifi weak signal. it pick up signal only within 1 foot from router range. And also not full signal..
any suggestion what I did wrong during battery replacement process.
Es esta una buena pregunta?
4 comentarios
This is just a guess after looking at the tear down on Ifixit. I would be looking at the flat antenna connections and making sure they didn't come loose. It looks like you could easily catch the antenna cable with the adhesive strip you pull out from under the battery.
- de Geoff Ice
you are talkin about the black strip cable...
- de Khurram Shahzad
I have this problem too. Can anyone solve it for me?
- de Umer
I check all the strips also antenna cable which is perfect, not loose but facing same problem very weak signal of wifi and Bluetooth this all due to replacing my fire phone battery.
- de Khizar Dawood
