Saltar al contenido principal
Modelo de mediados de 2012, procesador A1278 / i5 a 2,5 GHz o i7 a 2,9 GHz.
Preguntas 1624 Ver todo
Can I change for 16Gb (8Gb + 8Gb)?
Hi! My name is Ana and I'm from Portugal!
I've been searching on the internet and sometimes people say that apple says it cant (for money porpuses) and other people that confirm that it works!
I'm currently using (4Gb + 4Gb) and everytime I run photoshop and capture one the pc dies.
I would like to know if it would be possible to switch to 8gb + 8gb. https://support.apple.com/en-us/HT201165 I've seen this page but this is really confusing for me
Also, is this the best way to make to pc work faster?
Thanks for everything,
Best wishes,
Es esta una buena pregunta?
Puntuación 1
2 comentarios
For reference: MacBook Pro 13" 2.5 GHz i5 (Mid-2012) Note the amount of RAM this system can support is 16 GB!
What Apple has listed is what they tested. At the time larger RAM modules weren't available which is why Apple only lists 8 GB as the max.
The MacBook Pro system I'm using to write this has 16 GB of RAM. But you should also look at going with a large SSD (512 GB or 1TB) if you want use Photoshop or any other image/video editing app.
- de
I'm super greatful about the answers! Thanks a lot, Dan!
I'll search more about it, brands and prices and stuff!
- de
Agregar un comentario
1 Respuesta
Solución Elegida
hello there! no worry off course you can upgrade your ram up to 16gb here one working 100% exemple:
Crucial ddr3 16GB / 1600Mhz 204 pin [2x8GB] CT2C8G3S160BMCEU
best option for get faster your macbook pro is putting an SSD drive, allow you to write and read up to 500/ms against 60/ms. here an good price/quality exemple:
SSD 250GB Samsung 850 EVO SATA III
after installing clean os and program will be another computer.... good luck!
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Ana Marta estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 8
Todo El Tiempo: 115
