Released on September 19, 2014, this 5.5" screen iPhone is the larger version of the iPhone 6.
Preguntas 1226 Ver todo
"This accessory may not be supported" no charging
I have an iPhone 6 plus a customer brought in. The camera would not hold focus and the phone will refuse charge. I changed the back camera and it was fine. The charger port I cleaned out but it kept displaying an "accessory not supported message so I changed that as well. Still had the same message, so I cleaned out the pins on the board and the new charger port. Still the same thing. Ive tried updating, restoring, putting on airplane mode, ie. It only charges when dead and when it turns on it refuses charge. As soon as I plug it in it charges for half a second then instantly displays " this accessory is not supported". My chargers are original Apple and I've tried 7-8 different chargers. Im not really convinced this is hardware but I'm open to answers. Any help please, Ive tried everything I could think of except downgrading IOS and jailbreaking, and using bypass with cydia. However I highly doubt my customer would like to jailbreak her phone. It doesn't look like its been fixed before from my observation.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
Most likely U2 Tristar charging ic chip if you tried another charging cable.
As for the rear camera not focusing most likely you need to get it replaced.
por
Agregar un comentario
1 Respuesta
If you've tried this much I guess you might have to replace it. Is this iPhone new or old?
Fue útil esta respuesta?
Calificación 0
Añadir tu respuesta
Ali abdel estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 6
Últimos 30 Días: 19
Todo El Tiempo: 419
