Saltar al contenido principal
El modelo más delgado, más fino y más silencioso de la PlayStation 2 (SCPH-7XXXX) lanzado por Sony en Septiembre de 2004.
Preguntas 89 Ver todo
Replacing the optical drive of the PS2?
Hi, I have a PS2 that I bought second hand from a friend. Strangely, it works very well with my PSOne CDs, but when I put a PS2 DVD, it starts up, runs across the game opening and crashes. I've been told that is must be the optical drive - my friend must have used it as a DVD drive too - and would have to change. How do I do that?
Es esta una buena pregunta?
Puntuación 4
Agregar un comentario
1 Respuesta
Solución Elegida
Try cleaning your current one by getting either a cleaning disc that u put into the playstation or opening it up, most of the time the optical gets dirty or if you have an older playstation 2 then there is a gear the channels what media your system can play, if you search Google there are reviews on how to fix this problem. For parts you might check here http://www.mod-chip.com/ps2version.htm or here http://store.richspsxparts.com/pl2pa.htm... and if everything else fails go here www.ebay.com :) good luck.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Rodrigo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 9,980
