Saltar al contenido principal
Replaced broken screen now phone will not boot up
After replacing screen on the phone tried to power the phone. And nothing on the screen. Shouldn't I at least be able to hear something or vibrate from the phone it the phone has power. I disconnect the battery and waited a little while but still nothing. Went back to the old screen (because digitizer still worked) . But it did not show anything either. Please help!!
Es esta una buena pregunta?
Puntuación 1
1 comentario
Sounds like something might have come loose when you changed the screen, if it's still open can you trace your steps back and see if you've missed a connection?
- de
Agregar un comentario
2 Respuestas
Solución Elegida
No. Pretty much the last thing you wanna do is relace the logic board. I'm wondering if it's a missed connection also. Go back, check everything. Especially the power cable, on the top, next to the display cables. Also the Lightning connector. Did you disconnect the battery, when you took the display off?
Reemplazo de la pantalla del iPhone 5
Fue útil esta respuesta?
Puntuación 2
phone shows in itunes? check with magnifier for damage to board.
Puntuación 0
2 comentarios:
Thanks for replying. I Just plugged it into the computer and ITunes does not recognize device. Computer wont even recognize device.
- de
Does this mean that the Logic board is damaged? Would it be worth it to replace and sell the device?
- de
Añadir tu respuesta
Jacob Ramirez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 77
