Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
How to test if the Tristar has failed or the battery
just thought i would share with you a simple way to test if your charging fault is (board related) or (battery related) this test is simple and accurate.
start the phone and open up a app or menu to activate the wake up
now unplug the battery.
if the phone stays on then the tristar high speed switch is good as its switched to main voltage through the charger. the fault will then be in the battery.
if it powers off then the fault is in the tristar.
for fake charging the tigris ic will be the cause.
happy repairing
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 6
Agregar un comentario
2 Respuestas
Interesting info! You can also use an ammeter or something like the Kaisi battery activator ($20 unit with some other benefits for repair techs) to determine if the Amp draw through the lightning port is within normal range. I'm a bit hesitant personally of unplugging the battery while sending a charge through the lightning port. It maybe safe, but it seems like there is potential to cause issues due to how touchy the Tristar is to voltage irregularities in the first place.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
i just purchased and am not sure how to test and see if my battery is good any idea? i put the battery on tester but nothing happened until i plugged it into the power source. Is the battery bad or just dormant?
- de
check this out
tristartester.com
it works without taking apart your phone
Puntuación 0
Añadir tu respuesta
tonyhamre estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 1,451
