Saltar al contenido principal
Una videoconsola producida por Sony Computer Entertainment, también conocida como PS4. Anunciada el 20 de febrero de 2013 y lanzada el 15 de noviembre de 2013.
Preguntas 1695 Ver todo
Can a PS4 survive being submerged?
I had a burst pipe in my house and completely drenched my stepson's room which had a ps4 a few controllers and hdmi cords and so forth. I am wondering if they can survive that? my plan is to try and wait 24 hours before plugging it in and testing out but just wanted to know what others thought.
Es esta una buena pregunta?
Puntuación 1
6 comentarios
I woke up this morning and saw water all over the floor then it got to my ps4 and i put a fan in front of it for 2 hours and now it cuts on then make a little sound then it comes off plz someone tell how i can fix.
- de
same thing happened to me
- de
I had a mtn dew pour onto the couch where my console unplugged was sitting. When I realized what happened I immediately picked it up and turned it to its side to let it drain then took air duster and blew through the ports and fan vents. Is that good enough. Should I wait or what idk.
- de
Hi @glaciate85,
See the Chosen Solution and the Most Helpful Answer below, for what to do in case of possible liquid damage
- de
I dropped water into my PS4 and it turned off I waited 2 days still isn’t working does anybody know what I should do???
- de
Mostrar 1 comentario más
Agregar un comentario
3 Respuestas
Solución Elegida
aishaacoburn the very first thing you want to do is not wait. Waiting causes corrosion. Whatever damage has happened, it's done. Time to take a look at it and try to see if it is fixable. Use these guides to disassemble your PS4. Clean every part and every connector with 90%+ isopropyl alcohol and a soft brush. Yes, you can submerge the boards etc. Remove the power supply and open it up. Careful here, some of the caps may still pack a punch. Properly discharge those. Check for any obvious damage and clean the PSU the same way. It is important that you use the alcohol in a high enough concentration so that it properly displace the water. You can and should also clean the BR Drive since water can easily get in it and cause short circuits and corrosion. Only after you are sure you have it completely clean would I suggest a reassembly and give it a try. Again, the damage has happened but now it is time for you to troubleshoot to find out what has really failed. Any suggestion about which part (if any) may have failed will only be a guess until the PS4 is clean and inspected. Check with the console guru @tronicsfix on here for more help. See what he suggest how to proceed.
Fue útil esta respuesta?
Puntuación 4
1 comentario:
Is there a way you can do it with out tools
- de
Respuesta Más Útil
Well, first take it apart and dry everything. If you see green/blue/white residue, (corrosion) clean it with isopropyl alcohol and a toothbrush. Give it a new power supply. Once you are 100% sure it is dry, reassemble it and plug it in. Stand back just in case :)
Puntuación 5
4 comentarios:
It's not just the board that's the problem, it's likely there's an issue with the power supply, and the blue ray drive
- de
@theimedic how does the bluray drive fail?
- de
If it's been submerged in water, I'm going to guess its not at peak performance
- de
What if it was left on rest mode. Does this effect anything?
- de
Highly unlikely, and if it does, it will be very faulty. Going to have to source and replace a lot of components. Or buy a new system.
Puntuación 0
1 comentario:
Not necessarily, if it was off then I cant imagine anything being burnt that bad except the PSU.
- de
Añadir tu respuesta
aishaacoburn estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 54
Todo El Tiempo: 27,622
