Saltar al contenido principal
Procesador Intel Core i7 de cuatro núcleos a 2.2 GHz (Turbo Boost hasta 3.4 GHz), 2.5 GHz (Turbo Boost hasta 3.7 GHz) o 2.8 GHz (Turbo Boost hasta 4.0 GHz) con 6 MB de caché L3 compartida.
Preguntas 772 Ver todo
Right USB Port doesn't work w/ Lightning Cable?
Hi folks,
I have another problem with my 15 inch MacBook Pro of 2015...
After replacing the screen twice, replacing the logicboard once due to technical problems and replacing the lower case including battery and keyboard due to a water damage, I can't use the right USB Port with original Apple Lightning Cables anymore.
Several external USB 3 HDDs working most of the time.
I reseted the PRAM and I did a Hardwaretest - without any problem signed.
Do you have any idea?
Greetings from Germany
Florian
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Check under system whether USB port is still available, recognized and used. Post results. Having used any other item that draws power from the USB port, add that item and see whether there is still current flow ( for example an iPhone, an iPod, a rechargeable battery.) post results.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I posted the infos below :)
- de
Hi Wolfgang,
I don't know if you are from Germany? Your name sounds like that.
The system information says that:
USB 3.0 Bus:
Treiber für Host-Controller: AppleUSBXHCILPTH
PCI Geräte-ID: 0x8c31
PCI Revisions-ID: 0x0005
PCI Hersteller-ID: 0x8086
Card Reader:
Produkt-ID: 0x8406
Hersteller-ID: 0x05ac (Apple Inc.)
Version: 8.20
Seriennummer: 000000000820
Geschwindigkeit: Bis zu 5 Gbit/s
Hersteller: Apple
Standort-ID: 0x14700000 / 19
Verfügbare Stromstärke (mA): 900
Erforderliche Stromstärke (mA): 896
Zusätzlicher Betriebsstrom (mA): 0
Integriert: Ja
Apple Internal Keyboard/Trackpad:
Produkt-ID: 0x0274
Version: 6.24
Seriennummer: D3H63772KA1GHMFAP5FF
Geschwindigkeit: Bis zu 12 MBit/s
Hersteller: Apple Inc.
Standort-ID: 0x14400000 / 3
Verfügbare Stromstärke (mA): 500
Erforderliche Stromstärke (mA): 500
Integriert: Ja
Bluetooth-USB-Host-Controller:
Produkt-ID: 0x8290
Version: 1.40
Hersteller: Broadcom Corp.
Standort-ID: 0x14300000 / 5
Erforderliche Stromstärke (mA): 0
Integriert: Ja
Kind regards
Flo
Puntuación 0
1 comentario:
compare current flow when appliance is attached. change cable or plug. if both unsuccessful, check usb port with multimeter: 1. 5V+, 2. D-, 3. D+, 4. 5V-, one of them is faulty.
- de
Añadir tu respuesta
floriandanker estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 144
