Saltar al contenido principal
El smartphone insignia de Huawei del 2016. Presenta un cuerpo sellado y una configuración de doble cámara trasera desarrollada en asociación con Leica. Viene en opciones de almacenamiento de 32/64 GB y seis acabados diferentes. Números de modelo EVA-L29, EVA-L19 y EVA-L09.
Preguntas 72 Ver todo
Camera and led not working huawei p9
Recently, i broke the screen and had the LCD digitizer replaced by a local guy. Upon replacement, the screen itself did not sit completely flush and there was a small glimmer of light that you can see through the side of the digitizer; no biggie all seemed to be fine.
however now the LED does not work (i open the flashlight app and nothing happens), Nor does the camera app work. When I open the camera app, the app dies and doesn't open. When i try an app that would USE the camera, there is an error message saying "the camera is in use by another application".
So-- I'm unsure if the camera or LED worked prior to replacing the screen. I honestly didn't think to check. The screen was damaged pretty badly.
Ideas.?
I have called Huawei US and as this model (the p9) is an "International model" they (Huawei) will not help. Which is weird. but alas true.
I know that this phone is not in the US yet, but it seems that if I can't fix it, it is a big risk to buy another knowing that if I break the screen, im screwed.. any ideas..?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
I have the same problem but after a battery replacement. The flashlight works however, but I had to activate it from the lock screen the first time (it was blacked out in the notification/quick settings)
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Chuck Colby estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 1,477
