The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
Preguntas 3447 Ver todo
How can I remove the digitizer
Hi guys. I tried to change battery but I found that the screen digitizer is separated from lcd. Furthermore it is attached to the motherboard and to the battery so i can't remove it. How can i remove it?
see the picture
https://postimg.org/image/n02sm54wp/
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
2 Respuestas
Solución Elegida
Ehh... It's a bit more complicated, to remove the digitizer, on iPhone parts. I would use this
iPhone 5s Reemplazo Montaje Pantalla
With this
iPhone 5s LCD Screen and Digitizer
Imagen iPhone 5s LCD Screen and Digitizer
Producto
$39.99
Fue útil esta respuesta?
Calificación 1
Comentarios:
I know but as i opened the iphone it was in this condition, probably because a chinese shop repaire it...
por
From your picture it appears the digitizer is still attached to the LCD. The display(glass, digitizer, and LCD) assembly separated from the frame it is adhered to, which the LCD shield screws into. Just remove the two screws from the bottom of the phone and try taking a pry tool to pry the frame up to be able to access the connections on the motherboard. Then if the display is in working condition you could re-adhere it to the frame with some adhesive or replace the whole display if there is another issues with your current display besides it separating from the frame. Beware of the home button cable when prying the frame up. Make sure to disconnect the home button cable before fully lifting the frame out to avoid tearing the cable.
Calificación 1
Añadir tu respuesta
Linpeng Zhang estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 52
