Saltar al contenido principal
Segunda generación multi -touch, ratón inalámbrico lanzado por Apple el 14 de Octubre de 2015. Modelo A1657.
Preguntas 22 Ver todo
The top casing feels "loose", any way to fix it?
Ever since i got my Magic Mouse 2, the top plastic casing has felt kinda "loose" and a bit wobbly, so every time i loosely click it or run my fingers over it, it does not feel good.
Is there any way to fix this, apart from buying a completely new one?
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
@erikeia, Erik Eia , Ifixit rated trying to repair this mouse a 2 out of 10. From the link #1 below you can see the tear down, to see if you want to attempt to open the mouse and see if you can repair loose /wobbly case. If the top is just a little loose from the bottom you could try a little fast setting gel glue at the seam. Link #2 is just an example of glue that may be used. make model # and your complete question, so we at Fixya can answer your question effectively.
Magic Mouse 2
http://www.gorillatough.com/gorilla-supe...
Fue útil esta respuesta?
Puntuación 6
1 comentario:
I´ll see, thx
- de
Añadir tu respuesta
Erik Eia estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 44
Todo El Tiempo: 4,418
