Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
phone screen flickering and/or vertical lines
The phone screen alternates between flickering in a light magenta shade and displaying vertical lines. Phone is completely usable, just now with shades of color tossed in the mix.
Sounds to me like a damaged LCD cable, but I haven't taken it apart yet. I've worked with electronics repair, just not iPhones. Point me to a guide?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
2 comentarios:
Once any LCD cable or LCD gets damaged you pretty much need to get the screen replaced.
- de
my phone has lines and is glitching and has green spots on it. I have the 8plus
- de
Agregar un comentario
3 Respuestas
You may need a new screen or take the screen off and examine the connection cables of the ribbons and mother board. If the brass teeth are not perfectly aligned GENTLY drag a razor blade tip along then to realign them and CAReFULLY reconnect them
Fue útil esta respuesta?
Puntuación 0
This could just be down to dirty contacts, you can try gently cleaning the contacts with a toothbrush whilst checking if any of the contact pins are bent or not aligned, you have to be very careful not to damage any of the pins.
Puntuación 0
Took phone into Telstra and even they were dumb ass dumbfounded finally gave me new phone but I want to fix the other
Puntuación 0
Añadir tu respuesta
Thor Kamphefner estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 13,503
