Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3530 Ver todo
Replacement screen fades to white.
I'm currently having issues with a new replacement LCD for a IPhone 5s that I planned to install for a friend in her phone. However, this LCD required me to transfer all the additional part (camera, earpiece, etc.) to the new LCD.
Upon reconnecting the all the cables, and before closing the device up, I turned on the phone to test it, and noticed that when attempting to fold the flex cable into place the screen would fade to white. But when returning the screen to a 90 degree angle to screen would function as normal. In addition, the new screen had no touch capability whatsoever.
I noticed a small piece of plastic sticker pealed off the digitizer, revealing three contact points.
Es esta una buena pregunta?
Puntuación 1
1 comentario
Flex cable is damaged. And that 3 contact points is for the backlight cable.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Ideally, if you can easily replace the screen under warranty, that should be your first option. However, if that is difficult or impractical, cut a small piece of electrical tape to cover those exposed contacts. When you fold everything in place, they touch the LCD backplate and short out, which is causing your problem.
Fue útil esta respuesta?
Puntuación 3
1 comentario:
No dice, the screen will only work when the digitizer is at a odd angle. I will try to claim warranty or return it.
It's been rocky, first usps doesn't deliver it, then I get sent the wrong replacement and now this, whew.
- de
Try a new screen and return the old one, sounds like a crappy screen.
Puntuación 1
Añadir tu respuesta
James estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 1,661
