Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
Preguntas 3932 Ver todo
iPhone 6 will not turn on after being left on overnight.
We have a recent client that has been having this issue reoccur. When he gave us the phone it would not respond to anything. we tried plugging into a PC to connect using iTunes with no success, would not show a red low battery when pressing the sleep/wake button, no charging indicator when plugged into charger, Home + Power held for 30+ seconds with nothing. So after opening up the phone and testing a new battery on it, it booted right up. So I charged the battery to full and left it on overnight ( off the charger) to see if it would just randomly turn off and see if it would do it again. I come in this morning and the phone is back to doing what it was doing before. Does anyone have any insight on what may be causing this issue.
P.S. The phone has was factory reset so i doubt it would be a software issue that is causing this. All answers will be appreciated!
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
Throw it on an inline voltage tester and see if its pulling in any pixies. It sounds like it could be a bad power IC but that's just a guess without more info.
por
Agregar un comentario
1 Respuesta
Solución Elegida
No charging and fake charging are common symptoms of a defective power IC (Tristar), as @joshw says. Have you been able to see if it pulls any current?
The other thing is using a known-good battery to eliminate that possibility first. There are lots of poor quality batteries on the market.
Otherwise, you should consider a repair shop that can do micro-soldering repairs. They will be able to properly diagnose your problem.
Fue útil esta respuesta?
Calificación 2
Añadir tu respuesta
Shawn Hancock estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 79
