Barrel has been incorrectly installed
Hi,
I'm really hoping someone can help me!! My 8 year old son saved all his money to buy a nerf doominator. It arrived while I was at work. He took it out of the box and a 9 year old friend said he knew how to install the 2 barrels and did it for him. He managed to install one no problem, but the second one he somehow managed not to align the bottom but clicked the top in place. This mean the barrel sticks out. I need to unclick it from the top to reinstall it properly. No matter what search parameters I have tried, I can find no instructions on how to unclip the top. PLEASE can someone help us? I'm worried it will break if we keep trying without any idea what we are doing......
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
Hi
Were you able to fix the problem? Even my son wrongly placed the barrel and it is stuck now which is needed to be taken out.
Regards
Ritesh Sharma
India
por
Agregar un comentario
2 Respuestas
Solución Elegida
Hi Ritesh,
Yes I managed to fix the problem. If you use a long flat blade screwdriver, you can push aside the plastic part that stops the barrel from coming out. I didn't put it together the first time so I didn't know how it slid together. If you use a flashlight and see how the plastic slides together you can see what locks it in place. It is just a plastic ridge that you can push aside.
I hope that helps.
Anita
Fue útil esta respuesta?
Calificación 1
Comentarios:
Hi Anita
Thanks for the revert. Did you slide it aside or pressed the ridge inside to push out the other ridge out.
Regards
Ritesh
por
I tried this but it is still stuck
por
Someone please help. My son was trying to modify his doominator and the second he opened it up all the parts fall apart. Can someone please tell me how to fix it from the point where all pieces fall apart? Please help my son won’t stop crying. Thank you
Calificación 0
Comentarios:
Thanks for this post. My 9 year old attached the barrel part without aligning the back end first. Then my wife did the same to the other side. This post was a life saver, since I never saw the parts before misassembly.
A couple hints: From the FRONT of the rifle I slid a steak knife (didn’t have a thin flathead screwdriver and butter knife was too wide) slowly into the slot in the black plastic. Once the tab was pressed, the barrel attachment slid easily off toward the FRONT of the rifle.
por
Thank you!!! Definitely worked on the front NOT THE SIDE!
por
I too have this problem . I have a couple of questions
1)from the front of the rifle, at which side do I insert the knife/ screwdriver? From the front there is top, bottom and inner side.
2) it seems to be a VERY narrow space. do I insert the screwdriver straight or at a slight angle till I encounter a tab?
hope anyone can clarify, thanks.
por
Añadir tu respuesta
Austin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 24
Últimos 30 Días: 136
Todo El Tiempo: 3,628
