Saltar al contenido principal
Show massage on display " E100-0001"
Shows error massage on "E 100-0001"
Es esta una buena pregunta?
Puntuación 8
4 comentarios
Can i get a display board for canon mf4820d printer by online
- de
Please tell me the price
- de
- de
canon image class mf 4412 printer error 201-0001 turn of the main power
and the same problem canon image class mf 4750 error 101-0001 turn of the main power how to solved the printers problem i will request the problem solved
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Hi,
Try a power reset and see if this resolves the problem for you.
Switch off the printer if it is turned on, then switch off the power outlet and remove the printer's power cable from the outlet.
Wait for 5-10 minutes.
Reconnect the printer's power cable to the power outlet, switch on the outlet, then switch on the printer and see if it performs normally.
If you get the same error message after doing this 2-3 times then the problem is either in the Laser Scanner Unit or the Engine Controller Board (one of these will have to be replaced).
Fue útil esta respuesta?
Puntuación 8
1 comentario:
- de
Añadir tu respuesta
esourcecomp estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 50
Todo El Tiempo: 23,308
