Can't connect to home wifi
My home wifi works on my other mobile phone and laptop. And I've connected on other wifi with A5, but at home I've got nothing. Please help! Thank you
Es esta una buena pregunta?
Cancelar
An Android smartphone by Samsung for the Asian market, known by many model numbers, released December 2014.
Hi
Does your A5 detect your home WiFi network at all?
If it does, have you tried the "forget this network' option, shut down and restart the phone and then try to reconnect again? If so what happens?
If it doesn't is your home network working on 5GHZ or 2.4GHz?
If it is 5GHz what channel have you set in the router?
Try setting the 5GHz channel to either 36, 40, 44, or 48 and see if the A5 detects the WiFi network.
Comentarios:
I've just did a reset on my router and it worked. Thank you very much!
por Maja
Thanks ! Changing the canal from "Auto" to 40 on my router did the trick and now the phone sees the network.
por Adrien M.
How do you change the routerchannel
por Ruth Scott
Hi @dianeruth ,
What is the make and model number of your router? (Info is usually found on a sticker on either the back or under the device)
por jayeff
DSL-3680 Broadband Wireless N150 ADSL2+Router
por Ruth Scott
Hi @dianeruth ,
Your router works on 2.4GHZ 'only' so the setting most probably will be on "Auto'
You can try making it a fixed channel but you may find that you select one that is a well frequented one in your area which may then give you interference problems which can affect performance
To change your D-Link 3680/3780 wireless channel, manually, follow the steps below:
Open your web browser.
Type http://192.168.1.1 into the address bar and press Enter on your keyboard.
Now enter your username and password. Your default username and password are both admin (this is case-sensitive).
Select Wireless from the menu on the left.
You can select a channel from the Wireless Channel dropdown menu.
Please note: Auto setting will automatically find the best channel for your router.
If you want to use an individual channel, you should choose either 1, 6 or 11 because these channels do not overlap with each other. If you still don't see an improvement, you can then try the other channels.
click Apply Settings at the bottom of the screen.
What is the actual problem that you are having?
por jayeff
My Samsung Galaxy A5 phone is not connecting to my wifi
por Ruth Scott
Hi @dianeruth ,
Has the A5 connected to your WiFi network OK before?
Can your A5 connect to another WiFi network OK?
Did you try the "forget this network" option as described above?
What exactly happens when you try to connect to your network?
Have you tried "resetting" your router? Switch off the router, wait for about 30 seconds and then switch it on again. Allow it to initialize and settle before attempting to connect to it using your A5.
Can you connect to your network using another WiFi device such as another phone?
Lots of things to try but I am trying to eliminate possibilities to narrow down what the problem is.
por jayeff
Hi jayeff
Many thanks for all your help.It is greatly appreciated.I have tried all above.Initially I could connect to other WiFi but my own.Then as the week went on I could no longer do this.My other devices connect fine.Yesterday I have returned my phone as it is still under gurantee.So I will wait to see what happens
por Ruth Scott
Hi @dianeruth ,
Thanks for letting me know. Hope it works out OK.
por jayeff
Ultimas 24 Horas: 26
Últimos 7 Días: 190
Últimos 30 Días: 685
Todo El Tiempo: 6,546
We have a chance to guarantee our right to repair electronic equipment—like smartphones, computers, and even farm equipment. This is a once-in-a-generation chance to protect local repair jobs—the corner mom-and-pop repair shops that keep getting squeezed out by manufacturers.
Join the cause and tell your state representative to support Right to Repair. Tell them you believe repair should be fair, affordable, and accessible. Stand up for your right to repair!
