Cant get cellular network working
I've tried everything! !!! I can't figure out how to get my phone to get cellular network!
Es esta una buena pregunta?
Hi,
Could you please verify the following:
That you have tried your SIM card in a known working network compatible phone to see if your SIM card works in it.
That you tried a known working network compatible SIM card in your phone to see if it works in it.
Your phone supports the following frequencies
2G: GSM 850/900/1800/1900MHz; 3G: WCDMA 850/2100MHz
If your SIM card network is not operating on these frequencies in your area then you will not pick up any signal for your particular network.
Not sure if this is the same for your phone as I cannot find a User Guide for it but try going to Home > Settings > Wireless and Networks > more > Mobile Networks > Manual Search. This should show all the networks that your phone can detect. Check if your network is showing in the list
Fue útil esta respuesta?
Hi, yes it does show my network but it says , " can't connect to this network right now , try again later "
Hi, Did you check the SIM card in another phone and another one in yours? You didn't say. Is your account activated?
My account is active & the Sim was working fine on another phone but now in neither phone! Ugh
Hi, Did you try another working SIM in your phone? If it also doesn't work then perhaps the SIM card reader in the phone is faulty.
If it does work then I suggest that you contact the network provider and get another SIM to try as perhaps yours may be intermittently faulty or is somehow incompatible with your phone.
What a carry on can't get it to work network said manufacturers should give me code
Nobody told me no customer support for cheaper handset
HELP please please
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,809
