Saltar al contenido principal
La versión mejorada de Nintendo de Nintendo 3DS. Cuenta con pantallas más grandes, mayor duración de la batería, mejor densidad de píxeles y un mejor diseño.
Preguntas 411 Ver todo
Power light turns on, but the speakers pop and it turns off.
So I was letting my 5 yr old brother use the device (foolish, I know, but I'm just too nice a guy for my own sake), and he dropped it on the ground. It immediately shut off and now what's happening is I press the power button, the light goes on, stays for a few seconds like usual, but then the speakers "pop" and the whole thing is off again. I tried opening it up but couldn't find anything I could recognize as out of order, but then again I didn't really go that deep. Does anyone know how to fix this?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 6
Agregar un comentario
3 Respuestas
Respuesta Más Útil
You should check the ribbon cable connection also may have a bad/broken fuse. You will need to test current of the fuses if the ribbon cables are fully seated.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
How do I check those fuses?
- de
How do you check the fuse
- de
The same thing is happening to me but one of the cables of the speaker is broken
Puntuación 0
1 comentario:
yeah i have the same problem but i spilled pop on it
- de
So I actually know what is happening here. A specific cable going from the mother board through the hinge without a light, to the top screen and speakers, is broken. This is caused by this cable being cut like scissors by the hinge. I cant really explain it well, but I know a You-Tuber who can explain it in detail and how to repair it. His link is here: https://www.youtube.com/watch?v=eAVDyIWg...
There is also a part 1 where he takes apart the 3ds, but its not a 3ds xl, so i recommend using the guide to replace the upper screen that ifixit has, but don't replace the screen.
Puntuación 0
Añadir tu respuesta
Ace in the Hole estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 667
