WD my passport ultra 2TB is not showing up on explorer.
Hi, everyone. My WD Passport Ultra 2TB external hard drive is not showing up in explorer when I plug it into the USB port in a "normal way". I have to connect it through a "bizarre way" to make it show up in explorer. I realizes there were threads related to the same issue, but it's not what I am looking for.
Let me explain the "normal way":
I have another 1TB WD (same model as my 2TB WD) which behaves in a "normal way". Just plug and play. Nothing weird! Once I connect it, the LED blinks for a few times for successful connection. Done. I can find it in explorer
Let me explain the "bizarre way:
The 2TB WD behaves in a "bizarre way". If I connect it in the "normal way", it will not show up in explorer, Diskpart, or Disk management no matter how long I wait. In order to make the 2TB WD to show, I have to process the following steps every time I connect this 2TB external hard drive: First, plug in the USB cable halfway through any one of my desktop computer's USB ports. Then, wait for the drive to show up in explorer. Finally, I can push the USB completely into the USB port. The difference is that the successful connection of the 2TB WD happens when the USB cable is half way into the USB port.
Troubleshoots:
That particular 2TB WD behaves in the "bizarre way" on my Win 7 desktop and my Win 10 Surface Pro 3. However, it behaves in the "normal way" on my friend's Win 8.1 laptop, Ubuntu or Mac OS X.
Since my 1TB WD is working properly, I try to switch the USB cables between them. The 2TB WD still behaves in the "bizarre way". Thus, I can tell it's not a USB cable issue.
Also, I have tried to reformat the 2TB WD based on GPT or MBR partition tables. It still acts in the "bizarre way".
Does anyone know or understand what really happen to my 2TB WD? (For examples, driver issues, broken WD connector, ... etc..). Just in case my 2TB WD fails to show up completely in the future and that "Halfway-in-USB" connection trick does not help me to access that 2TB WD.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
Hi, I assume that you do not have access to another WD 2TB HDD to compare to prove whether the problem is with the drive or with your PC? Have you tried connecting it to a powered hub to see if your PC is not supplying enough power to it?
Have you also tried this to test your HDD?
https://support.wdc.com/downloads.aspx?l...
por
Thanks for responding. I have edited the description of my question. Feel free to view it again, please. And thanks for your advice from the link. I can actually access the 2TB WD, but only in a bizarre way. I just want to find out why it does that. I have tried to scan for bad sectors with software, but reports are normal. I also tried the official "WD Utilities" software to troubleshoot the problem. It finds nothing problematic.
I tried your method with a powered hub as well. It makes no difference. The hub I have with power adapter: https://www.amazon.com/Sabrent-Individua....
por
Hi, Found this link where the guy was having similar problem to you. There are two solutions offered which solved the same problem in different ways.
http://www.tomshardware.com/answers/id-2...
por
I'll give it a try. Thanks for the link. Just to clarify. That 2TB drive was OK before. It became to act strangely just about 2 weeks ago. I just worried that would be a sign of complete breakdowns coming.
por
Hi,
Suggest then if possible back up everything that you can when you do have access just in case. After that try using the 12V adapter power connector to see if it stabilizes as per connection/appearance in Explorer.
It still may be a compatibility issue between your PC and it due to perhaps component variations due to age (slightly less voltage supplied etc - all this is guessing of course as you say it is OK with other computers)
por
Mostrar 7 comentarios más
Agregar un comentario
5 Respuestas
The most easiest way I discovered when encountered same kind of problem with my passport. in Control Panel go to Devices and Printers. That would be the only place you can see your passport visible. open its properties and then open drivers, simply uninstall it, come out unplug your passport drive. Restart your computer and insert/plugin your passport again into PC. It will automatically start installing drivers and here you can start using your passport drive comfortably.
Fue útil esta respuesta?
Calificación 0
Comentarios:
This did not work for me.
por
(For people still visiting my thread): First, thanks Aslam Tareen. I've tried to reinstall drivers under Device Manager. WD connection issue persists, so it's not a driver issue.
por
1. Try new cable
2. buy similar HDD WD and remove the new controller board and install on bad one.
Hope it fixes it, I am at the same place. All other nice recovery programs freeze when the HDD is connected!
Good luck
Calificación 0
Comentarios:
(For people still visiting my thread): First, thanks Denis. I've tried new cable. WD connection issue persists, so it's not cable issue. I've not tried Denis 2nd method. Others are welcome to try.
por
just go to start menu , win 7 , computer right click , manage , then storage , find hard drive , right click over size of hard drive and assign a letter. thats it. should just work . if not unplug and try somthing else.... warning , do not format , do not change anything, I am assuming that you have data on the hard drive you do not want to loose...
good luck.
win 7 ultra64 , WD 2TB , my passport ultra , purchased in 2014, USB 3, with DV6-6119wm (HP) laptop , 16gb ram , 1 TB SSD.
Calificación 0
Comentarios:
(For people still visiting my thread): First, thanks PS. When my WD fails to show up in Explorer, it fails to show under Disk Management as well, so it's not a driver letter issue. For people who cannot find their WD device under explorer but it is visible under Disk Management. Please try PS's recommendation.
por
It seems that pc in general keep a tally of unsuccessful connections in the registry....this can also happen to cd/DVD drives....Try using the rear USB ports as these connect directly to motherboard.....
The partial power on trick seems to relate to 5 volt rail spin up before the computer tryies to read the existence of the device....for some reason putting the device USB in all the way means the computer has finished reading for connected devices BEFORE the drive has reached optimal spin speed in order to allow the drivers to read the device as working..This could be due to poorly defragged drive...or the computer psu already in using its full resources on other peripherals....which means the external drive takes longer to spin up than it should.So e external drives have their own power supplies for this reason.
Calificación 0
Comentarios:
(For people still visiting my thread): First, thanks John's detailed explanation. I've not experimented on John's answer. However, I've tried to connect via the motherboard usb port. Problem persists.
por
Hmm. just had the same problem after an unexpected power outage. I removed it from my switch, and plugged it directly into a PC. Device mngr saw it, but not disk manager, or explorer. This worked for me as far as local usb was concerned:
-Device Manager > Disk Drives > Properties > Volumes > Populate. (not sure if this is necessary, just noting my steps, but it did show under Disk Explorer after this)
-Disk Explorer > Change Drive Letter and Paths.
For what it's worth, I'm going to steer clear of WD. I have a NAS that is giving me no end of headaches.
Hope this helps
Calificación 0
Añadir tu respuesta
xKase estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 111
Últimos 7 Días: 800
Últimos 30 Días: 3,306
Todo El Tiempo: 36,905
