The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
Preguntas 610 Ver todo
HELP. phone screen is black but I can still hear notifications
Help... so i was at school and i fell over and my bag was in my bag and i forgot about it then i went to go get it out and turn it on and it turned on but the screen didn't and i can still hear it when i get a notification just the screen is cracked and it wont turn on the display. What happened? How do i get it fixed? and how much would it cost
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
Free Shipping on all orders USD79.00 and up.
Visita Nuestra Tienda
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
3 Respuestas
Solución Elegida
I'm sure you have already hard reset it but if not do that if that doesn't work take the screen off and it might have a busted ribbon or just bad connection of the ribbon but it sounds like it's
your digitizer and it won't cost more than 30 bucks if you do it yourself.
Fue útil esta respuesta?
Calificación -2
Comentarios:
Sorry but he did just say the screen is cracked. And if the LCD has no display it's almost certain that there is a crack on the LCD probably on one of the corners (not the top layer glass).
Digitizer is just the touch screen layer. It is not the glass. The digitizer is fused together with the LCD anyway so it needs to be replaced as a whole.
Busted ribbon or bad connection is not the cause.
TL:DR - This is not the solution
por
Respuesta Más Útil
Either get it fixed by a repair shop or DIY (Do It Yourself), probably costs around $100 USD for someone to repair.
Or get it repaired yourself which is fairly easy to do. You can find the screen with the matching model number on eBay. If you do decide to repair it yourself make sure you buy the correct model.
Here is the guide to replace the screen:
Samsung Galaxy S4 Display Assembly Replacement
Source: I repair these daily every weekend.
Calificación 3
Same problem here, however after receiving a new screen & digitizer and replaced it I had the same problem - I suspect that something had gone on the motherboard itself?
Calificación 0
Añadir tu respuesta
alexturner5818 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 27
Últimos 7 Días: 215
Últimos 30 Días: 855
Todo El Tiempo: 5,845
